Re: Crank Main Caps on H
Posted by justin on April 19, 2002 at 21:01:26 from (209.23.152.141):
In Reply to: Crank Main Caps on H posted by TNR on April 19, 2002 at 18:02:33:
The main caps are specific to each engine. You probably should have the engine looked at by a machine shop to make sure that the mains are in alignment. If they are not, there may be a possibility that they can line bore it with the replacement cap. If not, a replacement block will need to be found..
Post A Followup
: Re: Re: Crank Main Caps on H
