Re: Re: Farmall A identification and Lube points
Posted by Jim on April 21, 2002 at 07:09:12 from (12.86.94.83):
In Reply to: Re: Farmall A identification and Lube points posted by Al Schuman on April 21, 2002 at 05:48:53:
The ID plate in on the inside left hand seat support. You can get your SN from ID plate, then look up your year model from the Research & info column.
Mine is an "A", but it has a foot throttle, and also has a "square piece" between the front wheels instead of the round pipe between the front wheels. Is this a heavy front end?
What is the best book to order for a Farmall "A". Which book gives the most info?
Post A Followup
: Re: Re: Re: Farmall A identification and Lube points
