Re: Flaw with unfreezing stuck engine with hydraulics
Posted by Steven@nd on April 21, 2002 at 09:51:51 from (12.23.184.185):
In Reply to: Flaw with unfreezing stuck engine with hydraulics posted by Bob in SE Nebraska on April 21, 2002 at 09:35:16:
I agree. My way of dealing with stuck engines is this: First, check the oil - if there is water you have problems, if there is no oil you have problems, if it has oil, good. Then I remove the spark plugs - if there is any major rust on any of them I remove the head to inspect things. If none of the spark plugs have rust on them I remove the valve cover to be sure that ALL the valves are loose to avoid a bent pushrod if the engine does come loose. If all valves are loose I then pull the tractor on gravel or grass with another tractor and ease the clutch out while in 4th gear (or 1 gear below road gear). I proceed to disengage and engage the clutch about 10 times - if the engine hasn't come loose by then It needs to be taken apart to see what is making it stick. I have had 3 stuck tractors this year and the 2 I have kept have had to been taken apart to unstick - resulting in broken sleeves and broken pistons to get them loose even at that point. Hydralic pressure works for single cylinder engines like the stationary engines I also work on. When you have multiple cylinders and more than 1 is stuck then you risk bending connecting rods or breaking the crankshaft. Steven
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
