Re: Generator or Alternator
Posted by Irv on April 21, 2002 at 11:12:25 from (198.208.223.35):
In Reply to: Generator or Alternator posted by Jim on April 20, 2002 at 19:34:32:
I have done something that seems to work, but some might find unconventional: I simply replaced the 6 volt regulator with a 12 volt, new 12 volt bulbs and a 12 volt battery. You have to polarize the voltage regulator for - ground. The instructions come with the regulator. The generator with the 12 volt hook up seems to put out 13+ volts. The gen. has seen 10 + hours with no visible effects. A gen. might be wired for 12 volts differntly than a 6 volt, but these units are so overdesigned anyway, it seem not to matter. Well, good luck. Irv
Post A Followup
: Re: Re: Generator or Alternator
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
