Re: A CRACKED BLOCK
Posted by Haas on April 22, 2002 at 04:55:06 from (129.37.117.244):
In Reply to: A CRACKED BLOCK posted by Jim on April 21, 2002 at 19:13:42:
This is where the C 113 and c123 engine blocks usually crack. Someone probably let it freeze. The block can be repaired and will likely last for years. I'd take the block out and find a good engine shop and have it welded. If does not sound as though your crack is very bad. The JB weld suggestion may work well for you.
Post A Followup
: Re: Re: A CRACKED BLOCK
