Re: Re: International 3414 industrial backhoe/loader
Posted by RPM on April 22, 2002 at 06:48:43 from (63.110.182.225):
In Reply to: Re: International 3414 industrial backhoe/loader posted by John in Maryland on April 21, 2002 at 13:22:46:
Oring leak is possible but not very likely, sounds like hyd pump still not putting out enough pressure, usually heat will expand main housing of pump because its aluminum, steel gears will not expand as much, this tolerance is very critical to pressure. This is normal complaint in systems when they are warmed up. 3414 was a IH Construction Equipment only, AG dealers usually couldnt sell them. It was a good machine in its day, way ahead of competition, it has to 40 years old, I delivered them new in the mid 60s. I would at least try new Hytran & filter, this needs to be done yearly anyway.
Post A Followup
: Re: Re: Re: International 3414 industrial backhoe/loader
