Farmall Tractors Discussion Board
Re: Re: Re: Noisey power steering-Int. 350 Utility
Posted by big fred on August 07, 1999 at 21:50:09 from (199.238.169.72):
In Reply to: Re: Re: Noisey power steering-Int. 350 Utility posted by Big Fred on August 07, 1999 at 20:19:26:
If you saw the condition of the power steering on my 300U, you wouldn't want my advice. My problem seems to be in the mechanical part of the steering gear. Binds pretty bad, I think it may be due to the steering arm bushing on the right side being worn. Leaks gear oil (not hyd fluid) pretty bad and has quite a bit of slop.
Post a Followup
: Re: Re: Re: Re: Noisey power steering-Int. 350 Utility
