Re: SMTA HELP!!!!!
Posted by RPM on April 22, 2002 at 07:56:37 from (63.110.182.225):
In Reply to: SMTA HELP!!!!! posted by Geoffrey on April 19, 2002 at 20:48:41:
This is common on older IH, usually simple fix, take out plugs in tower, take out pins, lever will come up, align notch in rails (3), examine end of lever, should have a spade shape with square edges, weld up if needed, examine pivot pins (2), they will wear/rust, should be smooth, replace if needed, rail notchs usually harder steel & dont wear.
Post A Followup
: Re: Re: SMTA HELP!!!!!
