Re: 1206 water in oil,five gal. where would this put the leak?
Posted by Honkey on April 22, 2002 at 11:08:14 from (64.68.163.26):
In Reply to: 1206 water in oil,five gal. where would this put the leak? posted by Red Reaper on April 21, 2002 at 20:23:45:
Alot of water will enter through the exhaust stack. And work it's way down around the rings. You should be able to tell, the sleeve would be rusty or discolored.
If you have a crack in your oil cooler, you would have oil in the water, not water in the oil. Oil is under much more pressure than water.
But it has set for several years without enough antifreeze, so it could be cracked. I would think that it would crack the outside housing of the cooler before anything would crack inside of it, but it might have. I would take off the oil filters and apply pressure again and listen.
Good luck,
Matthew in SD
Post A Followup
: Re: Re: 1206 water in oil,five gal. where would this put the leak?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
