Farmall Tractors Discussion Board
Rough running 560
Posted by AJ560D on August 08, 1999 at 03:46:19 from (208.255.215.178):
This spring our 560D would rev up on its own for a few seconds the return to set speed. Now it's doing it all the time.If you let it go it will return and run fine.But if you throttle back,it will run rough for about a minute then straighten out.This problem is getting worse as the summer goes on.Also it doesn't smoke at all while it takes it's fit.
Thanks for any help.
Post a Followup
: Re: Rough running 560
