Re: Re: Flaw with unfreezing stuck engine with hydraulics
Posted by Jailkeeper on April 22, 2002 at 18:55:53 from (12.35.97.138):
In Reply to: Re: Flaw with unfreezing stuck engine with hydraulics posted by Thanks for the reminder - Dan Kelley on April 21, 2002 at 20:05:22:
Keep in mind if you take the crank out then apply
hyd. pressure to the top of those pistons, when
they break loose they are going to be MISSILES!!
There will be no way to tell when that piston is
about to come loose and you could have several hundred PSI on top of it. You could risk breaking
the block if the piston and rod come flying out of the cylinder. My .02, use a sledge and block of wood to drive it out.
Post A Followup
: Re: Re: Re: Flaw with unfreezing stuck engine with hydraulics
