Re: 300 Utility: 6 volt to 12 volt conversion
Posted by cd on April 22, 2002 at 19:53:44 from (205.130.17.56):
In Reply to: 300 Utility: 6 volt to 12 volt conversion posted by Paul Thale on April 22, 2002 at 07:52:33:
I would really consider NOT doing a conversion, these tractors were sold with well working 6 volt starting systems. I would concentrate on making sure that all connections are good and your starter is up to standards, unless you have a real reason (electronic ignition for example) I would let it alone and make it right. Just a thought...
Post A Followup
: Re: Re: 300 Utility: 6 volt to 12 volt conversion
