Re: Going to an auction, IH 574 info needed
Posted by Ray on April 22, 2002 at 19:54:11 from (40.0.40.10):
In Reply to: Going to an auction, IH 574 info needed posted by kb on April 21, 2002 at 18:32:36:
Warm it up good (work it for 45 min)and check the oil pressure at idle. If the instrument panel pressure meter reads one third from the left of the guage then you're good to go. Often the diesel engines cam, main and balancer wear at about 4 k hours to the extent that it affects oil pressure when warm. This is a must. If the guage is out put a store bought guage on it. and I'll repost with the required specs. Check the wiring harness. If the botttom of the tool box is rusted out it's been setting out most its life. Put something on the 3 pt and check for full lift. Listen to the transmission in all gears. If the emergency break works someone just fixed it or it was well taken care of! That's about it for now.
Ray
Post A Followup
: Re: Re: Going to an auction, IH 574 info needed
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
