Re: How to check rear axle bearings in International M
Posted by RPM on April 23, 2002 at 07:03:27 from (63.110.182.225):
In Reply to: How to check rear axle bearings in International M posted by Dennis on April 22, 2002 at 20:22:25:
Axle bearings can be checked/replaced through pto hole in back of tractor, drain lube of rear, remove pto, jack up one side, remove wheel, twist axle with big pipe wrench to remove cap screw on inside with breaker bar & socket, use a spacer between one side and other gear bolt to push the axle out of spline of bull gear, you can change the inside bearing of the axle, then check the outer and reverse this method. You have to drive the axle & outer back in axle housing with care, also use a large/long pry bar and get the bull gear started back on axle. We did this many times at IH dealer back in 60/70 with mounted pickers, will work on M-SM-400-560.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
