Re: 574 hydraulic problems
Posted by Harold Hubbard on April 23, 2002 at 19:11:38 from (216.114.181.161):
In Reply to: 574 hydraulic problems posted by Clark on April 23, 2002 at 18:37:22:
There is a good chance one of your brakes has given up, and the remains are lying in the bottom of the trans case. After the tractor has set a while you can start it up and the hydraulics are fine. You run it a little and suck that crud up into the intake screen of the hydraulic pump and plug it, the hydraulics stop working. If you shut it off and let it sit,all that stuff falls off and the hydraulics will work briefly, when you start up again. I have seen this on a 574 and also on a JD 2040. In both cases the brakes were completly trashed, and the remains of the linings were lying in the bottom of the case.
Post A Followup
: Re: Re: 574 hydraulic problems
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
