Re: what is External Resistance?
Posted by Dan Kelley on April 24, 2002 at 13:13:02 from (63.104.174.146):
In Reply to: what is External Resistance? posted by jtwaldo on April 24, 2002 at 12:44:56:
External resistence is that little (usually ceramic) gizmo that drops the ignition voltage going to the coil. On a Dodge, Chrysler or Plymouth of the 60's, 70's and 80's there was usually a 2- or 4-terminal ceramic block attached to the firewall, through which the ignition voltage went. Almost every other car maker did this as well. Haven't got a clue as to why they did. In any case, using a coil that was intended to have external resistence, and not giving that coil the resistence will result in a greater spark and a much-more quickly burned-out coil. The greater spark at greater voltage is a neat trick. You can get away with using that property for very short periods of time. The reason Dodge used a 4-terminal resistor was it used half the resistor (lower resistence) on starting, and the other half (higher resistence) on running. When the key was turned, the spark was boosted to help start the car. I found this out the hard way, when I had a Dodge that tried to start, but died when you let go of the key. The running side of the resistor block was blown, but the start half worked OK. Ford had a similar kind of thing, using the "I" terminal on the starter solinoid to bypass the resistor and feed 12v to the coil on starting.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
