Re: int 450
Posted by Steven@nd on April 24, 2002 at 19:33:25 from (12.23.185.176):
In Reply to: int 450 posted by joe sershen on April 24, 2002 at 19:12:57:
When it won't come out of gear, try pulling the TA lever back. If it then comes out of gear fine you need to adjust your TA and clutch - you will need an owner's manual or I&T manual to do this properly.
When you push the clutch in the TA should release to low range automatically in order to make shifting easier.
If the TA isn't the problem then it is usually the end of the shift lever, or the pin that the lever pivots in.
Steven
Post A Followup
: Re: Re: int 450
