Re: Zenith-Carb problems
Posted by wkend farmer on April 25, 2002 at 07:11:31 from (205.165.231.96):
In Reply to: Zenith-Carb problems posted by Cobo on April 24, 2002 at 19:25:31:
check for an air leak at the top plate and main body...the main jet adjust is for off idle operation only but does influence idle mixture slightly...again I would look for an air leak or a blockage in the emulsifier tube good luck !!
Post A Followup
: Re: Re: Zenith-Carb problems
