Re: Re: Re: Repair of International 1486 Hydralic System
Posted by cb on April 25, 2002 at 13:09:54 from (207.54.105.157):
In Reply to: Re: Re: Repair of International 1486 Hydralic System posted by Martin Petrillose on April 25, 2002 at 06:53:21:
If he heard somekind of a lound pop. It sounds like the system was over pressurized somehow.
I would start with the relief valve and see if it stuck closed and then blew open,and is now dumping all of your system pressure. Hopefully it didn't damage the pump or other items. Also I'm guessing you don't have any pressure from your remotes.
I know this happened on our cousins tractor and he had to replace the relief cartridge and a remote blocks. He was lucky the pump was still ok.
Also have a good look in the filter housing and check for any debry or metal parts. If theres lose items in the system they eventualy end up in the filter. (i.e. springs ,clips etc.)
Good luck
Post A Followup
: Re: Re: Re: Re: Repair of International 1486 Hydralic System
