Re: Re: riveting rear steel wheel hubs for Farmall Regular
Posted by Loren Pribyl on April 25, 2002 at 14:09:39 from (209.150.202.19):
In Reply to: Re: riveting rear steel wheel hubs for Farmall Regular posted by Ludwig on April 25, 2002 at 13:58:03:
I'm considering using bolts also. There is a round head ribbed neck standard bolt type that is similar to a carriage bolt, but it has raised ribs instead of a square area to prevent turning. The diamter of the ribbed area is about 1/32" larger than the threads. I thought if I use something like that, the heads would look similar to rivets on the front side, and use nuts on the back side. I'm thinking that forming the heads on rivets that large would be a difficult task, maybe impossible, without the right type of equipment.
Post A Followup
: Re: Re: Re: riveting rear steel wheel hubs for Farmall Regular
