Farmall Tractors Discussion Board
Re: H Water Pump (cont.)
Posted by The Red on August 08, 1999 at 13:37:40 from (12.75.221.98):
In Reply to: H Water Pump (cont.) posted by Bill(Tx) on August 08, 1999 at 13:30:12:
Bill the adjustable pulley originally was held with a bolt and a locking nut. There are 4 indentations 90 degrees apart where you would tighten down the bolt once you got most of the play out of the belt. It may well be that the threads are shot on the adjustable pulley. Hard telling until you get out there and see it.
Post a Followup
: Re: Re: H Water Pump (cont.)
