Re: Farmall A or B or A B
Posted by gene b on April 26, 2002 at 09:57:54 from (63.15.137.63):
In Reply to: Farmall A or B or A B posted by samriver on April 24, 2002 at 19:25:36:
how wide are the wheels apart 4ft or more the numbers on the seat bracket might have been replaced with a different bracket that has A B serial number what do the numbers read below the #1 spark plug does the steering shaft have a u-joint or does it go to a gear-box how wide are the rear tires the assys can be changed from A TO B and back and forth I modify them from time to time for mowers such as a narrow front on an A SO THE MOWER IS WIDER THAN THE TRACTOR
Post A Followup
: Re: Re: Farmall A or B or A B
