Re: Farmall H 5th Gear
Posted by Mr. J on April 26, 2002 at 19:19:14 from (64.200.53.105):
In Reply to: Farmall H 5th Gear posted by Bob on April 26, 2002 at 18:59:13:
third party image
Bob,
On my 1939 M, the lockout screw is located under the rear gas tank support. The bolt was located directly in front of the shift lever, and the bolt had almost rusted into the transmission deck cover. I had to use a cold chisel to remove it. There was no head left on the bolt itself. However, the purpose of the bolt was to keep the shift linkage from going into 5th. It sounds like your tractor is going into 5th, I hope you don't have any larger problems. If you can get the bolt out, replace it with a bolt that is about 1.5" long. That should fix the problem. Good Luck!! I enclosed a picture of the bolt I removed from my tractor and the hole it came out of. You might have to cut and paste the address of the picture to see it.
http://www.geocities.com/tallfarmboy/Bolt.JPG
Take care,
Jared Jeffries
Post A Followup
: Re: Re: Farmall H 5th Gear
