Re: Re: Sqeeling belt and fan wont turn I need help
Posted by ScottyNY on April 27, 2002 at 06:57:46 from (128.59.6.52):
In Reply to: Re: Sqeeling belt and fan wont turn I need help posted by Scott A on April 27, 2002 at 06:12:30:
Looks like the Scotts are all up in a snarl, here. One grenade get us all, eh! Scott, if you can loosen the nut holding the fan on the bracket so you can get that belt off, you should be able to drive the tractor in if you don't have an excessive distance--travel in third if it's safe to do so. If you've really chewed he belt up already, go ahead and cut it off. The others are most likely right-my money's on a bearing in the fan. Good luck! Scotty
Post A Followup
: Re: Re: Re: Sqeeling belt and fan wont turn I need help
