140 Steering box back together
Posted by HavinFuninMO on April 27, 2002 at 15:58:14 from (64.196.152.46):
Finished up the steering gear box overhaul a little while ago. At the steering wheel I used to have 3/4 turn of slop and now I'm down to about 1/8. The bearings had a little vertical play in them and the key way between the flat worm gear and the shaft had been enlarged. The key had also enlarged the slot in the worm gear. The teeth on both gears were great, IMO. After cleaning everything up, I dropped the key in the keyway and welded it fast and then trimmed the weld down for a press fit. Next I pressed the worm gear onto the shaft over the key. Drilled a couple of 3/8 holes through the back side of the gear into the shaft and spot welded the gear fast as well. ( For good luck I guess, didn't want to have to go back in ) New bearings & seals and back together it went. Filled it with oil and turned the pipe plug into it's hole with a growing sense of satisfaction. The feeling disolved as the top of the plug snapped off leaving the bottom half in. So here I sit. Easy out ain't easy today. Don't want to drill it as I will fill the newly rebuilt box with shavings. ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? NOT "havin fun in MO" today
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
