Re: ammeter question
Posted by Bob M on April 27, 2002 at 17:47:16 from (66.66.72.246):
In Reply to: ammeter question posted by Kirk on April 27, 2002 at 11:03:54:
Kirk -
One ammeter post should have only one wire on it - the one that connects directly to the hot (battery) side of the starter solenoid. ALL the other wires (from the alternator or regulator "BAT" terminal, also the feeds to the ignition and light switches) should go to the other terminal.
If your tractor is negative ground, the single wire should go to the unmarked ammeter terminal, and the other wires to the "+" ammeter terminal. (The ammeter positive may be marked with a red dot instead of a "+").
Or if neither ammeter terminal is marked, simply hook up the wires to the ammeter then turn on the lights and check the ammeter. If the needle deflects to the left you are all set. If it deflects right, simply swap the wires on both terminals.
Post A Followup
: Re: Re: ammeter question
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
