Re: 2 point switch to 3 point
Posted by Hugh MacKay on April 28, 2002 at 10:05:18 from (209.226.247.48):
In Reply to: 2 point switch to 3 point posted by Rick Firari on April 28, 2002 at 08:26:13:
I have seen two different types of these. I had one for a Farmall 300, consisted of two forks each with ball on end for lower links. The upper link consisted of a couple of U type straps went around rockshaft and bolted to a square tubing, which top link fastened to. My brother has one on a 230 which is one piece. Two forks with U shaped notches at end of each. An A frame goes up from the two forks for hooking implement where top link normally hooks. His operates much like quick hitches seen on many new and larger tractors, in that he can back in with links below pins on implements and just lift. It has latches to lock implement in place. I have seen also a few locally fabricated set ups, that work well.
Post A Followup
: Re: Re: 2 point switch to 3 point
