valve settings on a H
Posted by Bob on April 28, 2002 at 14:42:41 from (166.102.96.24):
On my farmall h I set the valves to 0.015 cold. The tractor misses, so i was thinking of changing them to 0.20. cold. Would this be a good idea? Could this be what is causing this miss? Also i heard that when adjusting the valves you should adjust them by the firing order. Is this necessary? The way I have been adjusting them is I bring no. 1 cylinder up on TDC and adjust both no. 1 and 4 cylinders then bring no. 2 and 3 up on TDC and adjust both of them. Any ideas would be appreciated. thanks!
Post A Followup
: Re: valve settings on a H
