Re: cub fan (hub assembly)
Posted by Gray on April 28, 2002 at 17:45:14 from (64.12.107.53):
In Reply to: cub fan (hub assembly) posted by jon on April 28, 2002 at 16:28:09:
I just had a fan hub from a Super A apart yesterday and there is no seal on the rear of the shaft. I think the oil level is critical to the hub not leaking around the shaft. Be sure to let hub oil drain to the correct level with filler screw out and pointed down. The stand pipe inside the hub retains the proper oil level.
Post A Followup
: Re: Re: cub fan (hub assembly)
