Re: farmall h kill switch
Posted by howard on April 28, 2002 at 17:57:29 from (65.172.143.72):
In Reply to: farmall h kill switch posted by Bob on April 28, 2002 at 14:36:29:
New old stock switches are expensive. there are some aftermarket repacements out there but they ain't cheep either. I'd try soldering the terminal back on, if it don't work you ain't out much. otherwise check with your friends for a good used switch. I have seen a regular push-pull switch used; just ground one terminal; but the the switch will work bacwards, that is out for stop.
Post A Followup
: Re: Re: farmall h kill switch
