Re: cadet original won't charge
Posted by The Red on April 29, 2002 at 07:15:39 from (206.246.187.2):
In Reply to: cadet original won't charge posted by Jeff on April 28, 2002 at 16:18:17:
Jeff I have a CC Original also. First thing I would do is remove the cover on the voltage regulator and make sure the points are closing when the engine is running. If that is OK, you will probably have to take it to a good alternator shop and have them go through it.
Post A Followup
: Re: Re: cadet original won't charge
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
