Re: still struggling!
Posted by Keith on April 29, 2002 at 08:24:33 from (65.69.154.126):
In Reply to: still struggling! posted by Kirk on April 29, 2002 at 08:19:42:
Use your multimeter. I have found that a charging alt will put out 14-15 volts when running. A 12 volt battery will output 12 volts. That is how I monitor mine from time to time. Guess I could just install a volt meter...huh? That would be too easy, no use making things too simple.
Post A Followup
: Re: Re: still struggling!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
