Re: cadet original won't charge
Posted by Harold H on April 29, 2002 at 09:46:31 from (207.244.60.72):
In Reply to: cadet original won't charge posted by Jeff on April 28, 2002 at 16:18:17:
With the engine running, short across the two startergenerator terminals momentarily and see if you have sparks/fire. If you have sparks/fire then your regulator is probably bad and replacing the regulator should solve your problem. If you do not get sparks/fire across the two startergenerator posts then your startergenerator is bad and you will have to get it rebuilt by a alternator/generator shop.
Harold H
Post A Followup
: Re: Re: cadet original won't charge
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
