Re: Should I Use 93 Octane on my M C's
Posted by Bob Kerr on April 29, 2002 at 10:37:48 from (205.188.197.32):
In Reply to: Should I Use 93 Octane on my M C's posted by Farmall Don on April 29, 2002 at 07:36:45:
Usually you will hear the engine ping if it needs higher octane or if the timing is way off. If it pings bad it won't take long for a piston to get screwed up and it also will pit the valves.
Post A Followup
: Re: Re: Should I Use 93 Octane on my M C's
