Re: Re: 826 D
Posted by Dick on April 29, 2002 at 10:49:29 from (208.7.129.45):
In Reply to: Re: 826 D posted by Honkey on April 28, 2002 at 17:42:31:
You were lucky, anti-freeze will keep oil from doing its job and most of the time the bearings fail because of it.A friend of mine had a 5020 JD, he figured it was an o-ring, so he ran alachol in the cooling system instead of anit-freeze. He would make sure to check the drain plug when it was cold before firing her up for the day. My 2 cents
Post A Followup
: Re: Re: Re: 826 D
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
