Re: Is it supposed to run out?
Posted by Haas on April 29, 2002 at 11:03:16 from (129.37.117.243):
In Reply to: Is it supposed to run out? posted by mwkellner on April 29, 2002 at 09:53:23:
When you fill the fan pulley hub, turn the hub so the fill hole is in the horizontal position. Then fill up to the bottom of the hole. Then turn the hub so the fill hole is on the bottom and let the excess drain out. There is a little stand pipe inside so that it just drains to the proper level. Then turn it back up and but the screw with washer in the hole. The shaft does not have much of a seal on it. Centrifugal force plus a slinger ring inside keeps the oil from coming out when it is running. If you fill it too full, the oil will just run out around the shaft.
Post A Followup
: Re: Re: Is it supposed to run out?
