Re: Re: Re: Farmall H Stumbling
Posted by Steven@nd on April 29, 2002 at 18:41:56 from (12.15.56.66):
In Reply to: Re: Re: Farmall H Stumbling posted by Bob on April 29, 2002 at 18:07:08:
Just turning the screws out doesn't make it right. You have to adjust them while it is running to make it run right. The idle air screw should be set just so it doesn't smoke at idle - in is richer and out is leaner.
The screw at the bottom of the carb is high speed, set that with engine at full throttle, turn it out until the engine starts to smoke, then turn it back in until the smoke stops. In is leaner and out is richer.
I would work on carb settings now before anything else.
Steven
Post A Followup
: Re: Re: Re: Re: Farmall H Stumbling
