Re: 24 Volt Battery...?
Posted by Hal Davis on April 30, 2002 at 09:30:02 from (12.21.137.126):
In Reply to: 24 Volt Battery...? posted by Terry on April 30, 2002 at 09:12:57:
How many cells does it have? A lead/acid battery will give roughly 2 volts per cell (actually a little better than 2). A 12 volt battery will have 6 cells. If you have two 12 volt batteries in series (one grounded with its + side attached to the - side of the other and the + side of the second battery connected to the electrical system), you will have 24 volts between the + side of the second battery and ground, even if the positive cable is disconnected. You should read 12 volts across either battery even if they are connected. Hope this helps.
Post A Followup
: Re: Re: 24 Volt Battery...?
