Re: IH 400gas - won't start- won't even fire
Posted by jal-SD on April 30, 2002 at 13:54:36 from (64.68.166.199):
In Reply to: IH 400gas - won't start- won't even fire posted by sillysnake201 on April 30, 2002 at 10:22:04:
My '45 H gave me lots of problems not wanting to fire from time to time. Several problems were located & fixed. First, make sure the bolt (the one that brings power from the coil into the points/condenser) that goes through the distributor housing isn't shorting out-its supposed to have fiber washers that insulate it from the hole & from the case itself. Next, make sure the spring on the points isn't touching someting to ground it out. I finally had to have my distributer re-built, as the front bushing was out & that let the points end wobble & short out. (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: IH 400gas - won't start- won't even fire
