Re: Carb problem?
Posted by Bob Kerr on April 30, 2002 at 19:55:38 from (205.188.197.22):
In Reply to: Carb problem? posted by F20 in MI on April 30, 2002 at 04:53:02:
I wish you wer closer to Terre Haute, I would have you bring it over and I would get it straightened out once and for all. Since your in Michigan, I will say check the fuel line for plugging. As for the internal leak, I bet you have the float adjusted wrong, try lowering the float a little in the fuel bowl of the carb.There is a mark on the inside of the bowl on my 10-20 and there may also be on on an F-20 carb.If there is a mark set the top of the float even with the mark.I had a carb kit for my 10-20 have the wrong float setting info in it.I threw out that sheet and set the float to the mark and it ran perfect after that. Those old cast iron carbs don't go bad as often as a guy who rebuilds them will tell you they do!They are very simple in operation and if set right run great.If set wrong they cause all kinds of problems and just "appear" to be junk.Set it right and it could run the space shuttle!( well almost anyway, hehehehe) Good luck with it.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
