Re: Carb problem?
Posted by The Red Baron on May 01, 2002 at 05:31:16 from (205.188.196.31):
In Reply to: Carb problem? posted by F20 in MI on April 30, 2002 at 04:53:02:
I'm not positive what the float looks like in an F-20. However, in my F-12 it is a small brass canister. I had problem very similiar to yours and in the end what it turned out to be was a small hairline crack in the brass float. It was not obvious to the eye UNTIL I tried bending the tang on the float and it opened up. Otherwise it was impossible to see, even when looking directly at it. What was happening was that as it sat in the gas resevoir, it would eventually fill with gas and refuse to float at all. It flooded and gave the same symptoms as you describe even though I had everything set properly. Take your float out and shake it back and forth. I'll bet you will hear that it is full of gasoline. I just carefully soldered mine and it works just fine now.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
