Re: IH 400gas - won't start- won't even fire
Posted by James (MO) on May 01, 2002 at 07:42:52 from (63.62.231.55):
In Reply to: IH 400gas - won't start- won't even fire posted by sillysnake201 on April 30, 2002 at 10:22:04:
If you have access to a Volt-Ohm-Meter, with the ignition switch turned on, check to see if you have 6V on both of the coil primary terminals (ones with the nuts). If that's OK, pull off the distributor cap and rotor, crank the engine and see if there is a spark between the points as the engine turns over. Also see if you can wiggle the distributor shaft to determine if the distributor bearings are good. If the distributor appears OK, replace the points and condensor. Also check the high voltage wire from the distributor to the coil.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
