Re: Re: carb on Super C
Posted by Rob in Wis. on May 01, 2002 at 11:37:03 from (205.188.193.181):
In Reply to: Re: carb on Super C posted by geoff gauger on April 29, 2002 at 19:09:45:
Yes, the lever on the shaft was spinning. I used the tractor yesterday to pull a fertilizer wagon and the governor seemed to give me the right amount of power. I still don't have much range on the throttle control lever. Idle is in the middle, so I'm only working with 1/2 the range. I could lengthen the push rod to the throttle shaft, but I'm not sure if that would help. How do you synchronize the governor and the carb?
Post A Followup
: Re: Re: Re: carb on Super C
