Re: Farmall 300 oil pump
Posted by Ace Schrunk on May 01, 2002 at 12:41:53 from (209.180.99.213):
In Reply to: Farmall 300 oil pump posted by Jim H. on May 01, 2002 at 06:29:43:
The drive shaft right above the pump gear will wear bad some times which will cause low oil pressure, don't know if the shaft and gear is available or not today years ago it was as far as the bypass valve just weld the bypass hole in the housing shut and forget the bypass valve, that is all we ever did back in the 50' and 60's never had a problem.
Post A Followup
: Re: Re: Farmall 300 oil pump
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
