Re: IH 350 utility conversion to power steering
Posted by joe on May 01, 2002 at 19:09:03 from (66.43.207.226):
In Reply to: IH 350 utility conversion to power steering posted by Jay Heffelbower on May 01, 2002 at 18:06:25:
Yes, you can - you will need a new steering gear housing that has the hydro cylinder cast in, and a new pressure regulator for the hydraulic system (this fits next to all the valve spools). These parts come from parts tractors that came with factory power steering. The problem, however, is that everyone seems to have your idea, and parts are nearly non-existant.
Hope this helps
Post A Followup
: Re: Re: IH 350 utility conversion to power steering
