Re: A Magneto problems
Posted by Baggsy on May 02, 2002 at 05:39:04 from (159.238.6.56):
In Reply to: A Magneto problems posted by Mike on May 01, 2002 at 18:06:29:
Mike, I doubt that your mag is the problem. Mags are known for being robust and don't have the problems that distributor ignition have. Check out the ford "N's" board to see the problems they have with fords better idea. If it starts then the mag is at least usable. Once it dies, check for spark by hand cranking it and see if you don't still have spark. At the very most you just need a new coil for it available almost anywhere that works on mags. If you did have a coil ignition I would say that the coil was heating up and shorting out the primary windings, but Mags just don't do this very often. Check your fuel flow when it shuts down, sounds like you've got a blockage in there to me. E-mail me if need be and we'll get it figured out.
Post A Followup
: Re: Re: A Magneto problems
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
