Re: Re: how do you unstick a clutch?
Posted by Leon on May 02, 2002 at 08:07:29 from (207.254.200.72):
In Reply to: Re: how do you unstick a clutch? posted by Russ on April 29, 2002 at 16:12:37:
Old post but I will add to it anyway......
Had a Cub Cadet mower that this happened to very often. I would take a large long screw driver and from the underside, tap it between the clutch and pressure plate. It would snap unstuck.
Post A Followup
: Re: Re: Re: how do you unstick a clutch?
