Re: Clutch bearing for a cub cadet
Posted by Jay on May 02, 2002 at 10:19:10 from (216.111.12.193):
In Reply to: Clutch bearing for a cub cadet posted by Serge Caron on May 01, 2002 at 18:04:25:
What is the problem? I have had to replace two clutches, different tractors. The last one had to have the clutch adjusted to keep the bearing from hitting the clutch in the wrong spot, bad noise. The clutch was very grabby (reason for the repair), rear main leaked oil on disk. Much better now though. Jay
Post A Followup
: Re: Re: Clutch bearing for a cub cadet
