Re: Re: Re: Re: Farmal 656 Hydraulics
Posted by the tractor vet on May 02, 2002 at 16:06:54 from (216.196.13.150):
In Reply to: Re: Re: Re: Farmal 656 Hydraulics posted by Walter Allen on May 02, 2002 at 14:36:07:
Well , what needs to be done is a test of the system and see just what the problem is . You could have a weak pump or the persure releif could need replacing . It would be in your best intrest to have it flow rated to see what it needs and fix that, it would be cheeper in the long run . It only take about and hour and half to do most of the time is eaten up just getting the oil up to temp. for the tests. And since you plan on useing it for loader work i would install a higher pressure releif valve . And if it did need a pump then install the 17 gal pump with filter ext.
Post A Followup
: Re: Re: Re: Re: Re: Farmal 656 Hydraulics
