Re: Unique Features of Early Farmall A's
Posted by gene b on May 03, 2002 at 19:46:28 from (67.251.189.254):
In Reply to: Unique Features of Early Farmall A's posted by George from Alberta on May 03, 2002 at 14:32:02:
the grelle is different also the radiator is different i have a almost perfect grille with the 1/4 screws you can get the screws from OEM in BLOOMINGHTON ILL he has them advertised you would not be able to have them like original as they were fastened is a special way see if you can return the grill some guys have got bolts with the head size of the original turn the body down and put a nut on the backside does yours have the fastener under the crank opening or is it way down under on the bottom good luck
Post A Followup
: Re: Re: Unique Features of Early Farmall A's
